Fuel Caps
Discussion in 'General 1000RR Discussion' started by tuktuk, Mar 23, 2018.
  1. tuktuk
    tuktuk Elite Member
    Is there any difference in fuel cap fitting between 08 through to 16 year bikes? I always thought they were the same but im having doubts!
    Cheers.
  2. tuktuk
    tuktuk Elite Member
  3. roboticus
    roboticus Active Member
    yes I think there is, there was one on ebay, he said he bought it for a 12 plate and it was for a 14 plate
  4. tuktuk
    tuktuk Elite Member
    Thats the one I was after lol. Glad he rejected my cheeky offer now :D
  5. nigelrb
  6. roboticus
    haha I was going to do the same, told u I'm always on it
  7. vic_ster51
    vic_ster51 Active Member
    If you look at the top of the tank cowl from say a 14 bike compare it with 08, the tank sealing rubber on 14 is alot bigger. So maybe the cap itself is tiny bit smaller. Also i found out its stated by honda the 14+ fuel cap has better breather on it. If you look at parts fische you can see this on there.
    Im thinking only the couple parts from honda are needed the spacer and rubber sealing ring to fit them
  8. BikersDiscountStore
    04-13 are the same, 14-16 same, 17-18 same.
  9. stevet
    stevet Active Member
    The main difference between the 08-13 and 14-16 is the allen bolts on top went from 7 bolts to 5 bolts...and pressure breather ability. ..oh and the 14+ is noisy as fook
  10. stevet
