Fuel Gauge
Discussion in 'General 1000RR Discussion' started by MrB, May 21, 2012.
  1. MrB
    MrB God Like
    Help,
    Can anyone explain to me in the simplest of terms how the fuel gauge/range left thing works and what the counting numbers relate to ?
    Having read the manual I'm none the wiser
    Thanks
    Mr Thicko.
  2. Jamiestrada
    #2 Jamiestrada, May 21, 2012
  3. tonyblade
    tonyblade Active Member
    that's just what I do too Jamie :) when light comes on fill her up soon as.
  4. Remal
    If you have yours set like mine once the fuel light comes on it says 0.0. I have only managed to get it to 0.4. about 0.6 and you'll prob run out. I just do as you said, fuel up asap
  5. Moily
    Moily Active Member
    Provided you don't thrash the arse off it, I work on the basis that 0.1 will get me 5 miles so usually try and fill up within 30-35 miles of the light coming on when working out when to stop.
    Managed to get to 0.6 once but don't want to find out if it will hit 0.7!
  6. Remal
    my last Track day I forgot to fill up during one session and once I got to 0.4 on track I came in. was thrashing it so only managed 4 laps from fuel light on until 0.4 or about 7-8 miles. :eek:
  7. abv
    abv Active Member
    It's quite simple really.
    The number tells you how much fuel in gallons you have used since hitting reserve.
    When the light comes on you have 0.77 gallons of reserve fuel left.
    if the number gets up to 0.7 you are pretty much running on fumes.
    How many miles obviously depends on how you ride and how accurate it is I don't know.
  8. Mel
    Mel Active Member
    easy light on = stop messing around and get fuel :)
  9. MrB
    MrB God Like
    No one likes a smart arse ;) Thanks though.
  10. katoross
    katoross New Member
    2011 fuel gauge fire blade
    The reserve fuel on the 2011 fireblade is 4ltrs, this equates to 0.88 Gallons, so i presume the count is to let you know how much you have left of that 0.88 of gallon, obviously this is effected by how you ride a bike?i did realise that no Honda Garage i rung had a clue?,wow
  11. WyreFlyer
    WyreFlyer Member
    Reading from my handbook for a 2010 light comes on at 3.5l (0.92us or 0.77 uk gal) beyond that I can't make head nor tail of what it says, total gobadlygook!
  12. gary1966
    gary1966 Active Member
    As others have said fill up as soon as, i have only had the light on once i got to 0.4 but when i filled up i put in 14 litres so i should of had 3.5 litres left in the tank.
  13. JM1
    JM1 Active Member
    I ran out at 0.7
  14. skinso
    skinso Active Member
    In not 100% but neat sure I've had mine at 0.9, when i first got the bike the fuel light was on but I rode the bike home, once home I'm near sure it was 0.9 but I thought I had down to 0.0 until I was empty until my mate who is a Honda mechanic said it goes up and not down
  15. Fletch182
    Fletch182 New Member
    Hi. I'm new on here and pick my 2010 bike up tomorrow. I was also wondering how you gauge when to fill your bike up. Does anyone zero the trip and than gauge your distance left sending on the miles you've done? If so how many miles do you judge it on?
  16. Lozzy
    Fuel light starts flashing at 0.0 you'll have about 25 miles left. I've had it up to 0.9 but was sweating a bit on that so I'd try fill up by the 0.7 at latest
  17. bonjo
    bonjo Active Member
    As the other guys mentioned, light on = take it easy and look for a petrol station!
    the light comes on when there is 0.7 ukgal left so if you switch the display to avg mpg, then whatever you read x 0.7 will give the range (e.g if you read 50, then 50x 0.7= 35 miles:))
  18. Mr OCD
    Mr OCD Well-Known Member
    Yep, every time for the last 20,000 miles.
    Light comes on anywhere between 135-145 miles... after that I can do another 25-30 miles before filling up again.
  19. travellingkiwi
    travellingkiwi Active Member
    On mine (Uk Standard 2012 anniversary model) it's in litres... I have 2.5l at reserve IIRC... Or was it 3.5...
    H
  20. ASALMAN
    ASALMAN Active Member
    my fireblade 2013 as soon as reserve light came on my tripmeter showed 5.7 then 0.0 and now counting up but I really do not understand. full tank to reserve light she does 101miles
