Fuel?? Please help, How much do I have left?
Discussion in 'General 1000RR Discussion' started by andybow, May 25, 2011.
  1. andybow
    andybow Active Member
    Right, Can someone please help a numpty like me. Does it show how much fuel you have left on the computer or am I being a dick?
    Cheers Andy
    2009 hrc blade:confused:
  2. flatstickHRC
    flatstickHRC Active Member
    No iit shows how much you used since reserve light came on
    Mine is in gallOns and the most I've dared take it to is 0.6gallons into reserve
    You have a good 30-40 miles left when the light comes on.
  3. GSP
    GSP Active Member
    I was told 0.3 was the absolute maximum and then you would be out of fuel, and it's about 20 miles... 0.6 is damn good going
  4. GSP
    GSP Active Member
    I just read the owners book. Its says there is a 0.77 Imp Gal reserve. It's not clear wheter it counts up in litres or gallons though.
  5. Remal
    I have only had the light come on once and got to 0.2 and thought i was pushing it. Then only managed to get 14.5 ltrs into the tank so a good 3 ltrs left.
  6. dan.1moore1
    Dealer told me it count up to 3.0 but people have reported running dry at 2.6
  7. flatstickHRC
    If your trip is in mpg the reserve runs in gallons or you can have km/litres if you want
    I would say 0.77g is about right for the reserve.
    If you average 40mpg then you will get a good 30miles out of the reserve
  8. JM1
    JM1 Active Member
    Someone told me they've seen 1.1g on it!
  9. Rob
    Rob Administrator
    I think it's the most ridiculous way of counting down fuel! What's wrong with a simple countdown rather than count up? What genius thought of that?! Come on Honda, needs to be better on the next blade. I always wonder what is left. Never risk going over 0.5 myself.
  10. slowr1der
    slowr1der Active Member
    Took it to 0.5 on the way home from the bike meet last night, that was enough for me
  11. andybow
    Thanks everyone for the info! but I,m still confused, Why can't they just put a normal fuel gauge on!
  12. slowr1der
    who knows, why don't you fill in this feedback form and you can ask Honda UK if it is bothering you so much. I am sure they will happily answer the question
    Contact Us | Honda (UK)
  13. zeepony
    zeepony Active Member
    I was running very low in France heading for Calais and it went up to 0.9 so I believe JM1! I still only put 16.5 litres in the tank so there must have been more in there - think its 18 litre tank?
    Also, handy tip - if you are TOTALLY out, open the fuel cap... There is a vacum in the tank and when the top is open it draws more gas into the pump. So a mate told me APPARENTLY - never tried it myselt
  14. dan.1moore1
    I got to 2.1 yesterday
  15. zeepony
    Ok there is only one way to find out... Rob, u need to do a 1000rr test section! I'll follow u with a jerry can and run it till it's dry... I say u do it as I don't want to shank up my injectors!! :)
  16. flatstickHRC
    Your bike must be set to litres not mpg. Won't get 2.1 gallon on reserve. That's 9 litres!
  17. JM1
    JM1 Active Member
    "Proper" fuel gauges never actually work though do they (ie, they are not accurate).
    I reckon Honda went for something that's actually more accurate for measuring, but doesn't actually help the rider any more than other gauges.
    They also like to be different!
  18. dan.1moore1
    Aint got a clue mate but it said 2.1.. I was gonna wait for the next fuel station but jibbed it as the dealer told me it could run dry on 2.6 instead of 3.0 like honda say
  19. flatstickHRC
    Must be set in litres then cos that's about0.7 gallons like the handbook says is the reserve
  20. dan.1moore1
