Fuel Pump Relay?
Discussion in 'Maintenance' started by Mike07, May 1, 2018.
  1. Mike07
    Mike07 Active Member
    Sorting the bike for a European run, not been on it all winter. its a 2015 CBR1000rr SP ABS.
    Bike was starting and running fine, I unusually stopped it with the kill switch not the key, ive not done this before. Anyway itll now not start, Cranking over fine but not starting ....I can't hear the fuel pump running up. Any help appreciated.
    Mick.
  2. hitch
    hitch Elite Member
    You did retrun the kill switch to the run position? o_O
    I remember when I bought my 2015 bike the dealer bloke told me that the blades were unusual in that the engine will still turn with the kill switch set to off.
  3. Mike07
    It's not beyond me to do such a thing, but yes I remembered to re-establish the switch to it's run position.
    Thanks
    Mick.
  4. hitch
    hitch Elite Member
    Hmmm, well that’s a start I suppose; have you checked fuses?
    I’m not really much help am I here :oops:
  5. Mike07
    fuses okay..
  6. nigelrb
    Perhaps you might consider doing crosswords or Sudoku?:D:D
  7. CharlieR85
    CharlieR85 Elite Member
    I had trouble with my kill switch last year on my 2015. I had routinely been using it when waiting at long sets of lights etc. Then suffered the same experience as you a few times although it would start eventually. I cleaned out the kill switch and vowed never to touch it again. I only use the key now.
    Perhaps take it apart and bypass it to rule it out.
  8. Mike07
    Solved it, The kill switch thing was a good pointer, It was a bad connection. Prob the sit over winter, anyway all sorted and I've got a spare relay to take just in case.
    Thanks All
  9. CharlieR85
    Yes the kill switch really is crap, I actually considered replacing the starter/kill switch assembly with an after market one. The bike must have heard me and felt threatened, its been fine ever since.
