Full Yoshi question
Discussion in 'General 1000RR Discussion' started by tsfblade, Apr 26, 2012.
  1. tsfblade
    tsfblade New Member
    Could someone inlighten me on a full yoshi system?
    what happens to the Lambda sensor? and the baffel wire on the original systed?
    seem to have read somewhere there is a post on You tube refitting.... I dare say should of looked a bit harder before asking the above question
  2. JM1
    JM1 Active Member
    Don't know about the Yoshi specifically, but...
    Lambda sensor - you can either connect it up to your new exhaust or, if you're also installing a power commander, you can replace it with an O2 sensor eliminator.
    Baffle wire - assuming you mean the cable that controls the exhaust "flapper" valve, that gets disconnected when you fit an aftermarket system.
