Gasket or not
Discussion in 'General 1000RR Discussion' started by wurzel, Jul 1, 2014.
  1. wurzel
    wurzel Active Member
    I am looking at putting a new engine casing on to replace the scraped one I have on now. Will I need a new gasket or will the one coming off be ok to re-use. Clutch side 2009.
  2. thezipsteruk
    thezipsteruk Elite Member
    If you can get one easy enough Id put a new one on, going to be real annoying to find it leaks your fresh oil because you skimped!
  3. northseawarrior
    northseawarrior New Member
    If it's worth doing it's worth doing right and don't be tempted with instant gasket it's a bodge.
  4. jamesm09
    jamesm09 Senior Member
    Yeah get a new gasket, you don't want to do the job twice if it leaks.
  5. Ian E
    Ian E Active Member
  6. Ian E
    Ian E Active Member
  7. SimonRR
    SimonRR God Like
    Yeah I used that after replacing my clutch, there is no gasket on that side, you need a sealant
  8. scooby
    scooby Elite Member
    just use sealant,it doesn't need/have a gasket,although i think HRC might do them (try padgetts if your set on one)
  9. M3NTALIST
    M3NTALIST New Member
    The Honda bond was only £11ish iirc.
    Andy B
