Gb engine covers ,
Discussion in 'General 1000RR Discussion' started by keithg1748, Oct 8, 2018.
  1. keithg1748
    keithg1748 Active Member
    hi does anybody know when fitting these do the bolts have a torque setting ? as I don't want to overtighten them , cheers .
  2. F1CT1C10U5
    F1CT1C10U5 Well-Known Member
  3. 1000rr73
    1000rr73 Active Member
    10nm from memory. Instructions are on gb racing website. Best to check as there is a sealing washer to put back on and the bolts are a mix of 35mm and 40mm so they need to go in the right holes.
  4. 1000rr73
  5. keithg1748
    thanks for that but all the bolts are the same size , and does the copper washer for bolt 1 go on the inside of the case on the engine case or on the outside of the gb protector , cheers .
  6. 1000rr73
  7. keithg1748
