GB racing engine covers and HEL braided lines.
Discussion in 'Mods, Upgrades, Accessories and Products' started by f1nn, Sep 23, 2013.
  1. f1nn
    f1nn Active Member
    okay, so managed to drop the bike on its side on my driveway a while ago and although I got away with a scratch on the L/H engine cover and a scuffed clutch lever.
    Honda wanted 120+ for a replacement cover so I decided to go for a full set of GB Racing covers for less than 170 delivered.
    Fitted in less than 30 mins, great product, well made. Recommended.
    The front brakes on the blade were probably the weakest link, so I wanted to see if I could improve them slightly for pennies.
    Ordered a set of HEL braided lines from the friendly forum supplier. Fitted and bled (easiest bleeding of any bike I've had) And test rode. Definitely sharper and more responsive. Result! Again, Recommended!
  2. scooby
    scooby Elite Member
    i suspect it was the bleed that has given you better feel more than the actuall lines.
    GB covers are spot on though,i ahd a slide and did verty little damage to them,plus saved the main casing.
