Finally Arrived Easy to fit so i didn't bother with an installation guide Follow the instructions for the clutch side as there is 1 sealing washer that must be re used . ( i nearly missed it ) fit everything finger tight , then you need one of these bad boys All bolts to 10Nm and jobs a goodn !
Those look the business Dan. I'd have some for mine but I don't think they make them for the ABS model because some of the routing for the ABS gubbings runs down the left hand side
I only have them for the right side as the left has the plastic cover to protect the ABS wires etc... But glad thy are fitted. Also have R&G fitted
Ah rite .. i see . Im sure iv heard of an ABS option .. The god thing is thou Col , that they sell each protector separate as well so you don't have to buy the full set I already had GB Racing paddock bobbins so I'm only missing the shark fin for the swing arm now . ( Which has reminded me to order it ! lol )
Really rate these covers. Plus we damaged one at the TT in 2010, the guys from GB racing came and took the damaged one for testing and gave us a nice new one FOC. Top blokes!
We do yes mate , but as you said dude, everywhere is the same price. Direct from GB Racing is best if ordering via mail order.
Anyone got a scan or a pic of the fitting instructions?? In particular, Dan speaks about reusing a sealing washer... Also the bolts have different sized heads... Which are for where?? Thanks for any help on this!!!
I don't remember getting any instructions with them, but you don't need any - fitting is easy and obvious.
I am getting a set without instructions. Can anyone advise on what bolts I will need to make them fit?
