gb racing fitting instructions
Discussion in 'Mods, Upgrades, Accessories and Products' started by Remal, Jun 14, 2011.
  1. Remal
    Bought some from a very nice chap on here. But no instructions. Anyone have a link to help
    cheers :bananadoggywow:
  2. blade1980
    blade1980 Active Member
    It's quite simple, just line them up with engine casing you are fitting it over and remove the 3 or 4 bolts from the engine casing then fit the cover with the slightly longer bolts that you should have supplied with them, the pulse cover (R/H Side the three bolt one) top bolt can be a little tricky as it holds the clutch cable, i just slackened the fairing off and it made it alot easier to get to, hope this helps
    #2 blade1980, Jun 14, 2011
  3. Remal
    cheers for that.
