Gear indicator flashing “-“ ‘19 SP2 / unable to autoblip
Discussion in 'Maintenance' started by Kurt Levi Navarrete, Nov 27, 2024.
  1. Kurt Levi Navarrete
    Kurt Levi Navarrete New Member
    Hi All,
    Trying my luck here to find a fix for my gear indicator that is flashing that I think why my autoblip is not working. The upshift works like butter but it stopped doing autoblips.
    I have read through numerous threads from different forums to find a fix for this as it seems like a common issue to the 17-19 with QS installed but I’ve never found an answer.
    Thank you!
    - Kurt
  2. bladey
    bladey Senior Member
    Didn't know this was a problem. My 18 smooth as silk.
  3. buz
    buz Active Member
    Does it display - all the time or only on a missed shift?
    It usually displays - when the shift drum is in a position between gears, a false neutral.
  4. Kurt Levi Navarrete
    I’ve read a lot of threads having this same problem but never found a solid answer. Good for your sir. How many miles do you have now?
  5. Kurt Levi Navarrete
    It does flash all the time as long as you are in any gear. It doesn’t show when im in Neutral.
  6. dgr
    dgr Active Member
    You could try removing the QS and re-registering it. The process is described in the workshop manual somewhere. You don't need to physically remove it.
  7. bladey
    8500. Cross fingers going forward
    • Friendly Friendly x 1
  8. Kurt Levi Navarrete
    Ok ill give that a try. Did you have this same issue and that fixed it?
  9. dgr
    dgr Active Member
    No, but I fitted the QS myself, so had to go the process of registering it with the ECU. It's worth a try given your issue.
