Gear indicator with HRC LOOM AND ECU
Discussion in 'Mods, Upgrades, Accessories and Products' started by Dethers, Jan 30, 2014.
  1. Dethers
    Dethers New Member
    Trying to get the GI Pro working !!!!!
    No speed sensor from gearbox....anyone got an HRC gearbox speed sensor for 2009 engine???
    Or know if the standard one can be used and plugged into the ECU?
  2. The.kickboxer
    The.kickboxer Active Member
    Just plug it into the service port in the battery compartment is what I did with my, but I don't know what this HRC loom you talk of.
    #2 The.kickboxer, Jan 30, 2014
  3. Skippy79
    Skippy79 Active Member
    Race loom that takes away all the road needed crap (lights, fan, key etc etc )
    not sure myself otherwise I would have answered it for you mate!
  4. Mr_Spinalzo
    Mr_Spinalzo Active Member
    I think you have other Problems
    If your hrc loom does Not fit on the Speed Sensor , you have to Cut it oder change the connector
    You do Not Need the hrc speedsensor as long as You have stock gearbox
    The gipro connects to the diag Port of the loom
  5. Lifeofriley
    Lifeofriley New Member
    I have the same issue! Cut my hrc loom and spliced it to fit on to my 08 speed sensor! No single still, i have a feeling i need a 09 speed sensor as it is a different part number.
  6. BikersDiscountStore
    GIpro DS won't work with a kit ECU, GIpro X-Type with GPX-WSS sensor kit is the only option.
