Gear indicator...
Discussion in 'Mods, Upgrades, Accessories and Products' started by mk3golfcab, Oct 11, 2019.
  1. mk3golfcab
    mk3golfcab Elite Member
    looking to get a gear indicator for the bike. I always seem to forget which gear I’m in (unless it’s 6th o_O)
    Ideally want something that is easy to fit, works well (minimal lag - the one on my TL1000R was terrible), compliments the dash, and is under £100 - would be willing to look at some higher priced alternatives too.
    What are you guys using?
    Thank you :)
  2. nigelrb
  3. mk3golfcab
    Saw that earlier Nigel thank you, that post actually reminded me I want one. I have no idea why they aren’t “standard” on all bikes. Seems we normally get less equipment with the litre sports bikes!
  4. nigelrb
    We get them on 2017 - 2019s:D:D:D.
  5. mk3golfcab
    I need to upgrade :oops::(
  6. dessp2
    dessp2 Well-Known Member
    Weirdly enough I still shift up to find the next gear even though I have a digital indicator telling me which gear I am in on the dash. It’s a keep your eyes on the road thing.
  7. PauloHRC
    PauloHRC God Like
    Yep, Standard on the 17 19 models, there is still a bit of lag in indication of gear on the odd occasion though. I don't think that's a problem though as you don't need to know what gear your in instantly. I only look at it when moving down the gear box.
  8. Selmer50mark
    Selmer50mark God Like
    I Count out loud as I go through the gears :D lucky for me they only have 6 :D:D
    • Funny Funny x 4
  9. PauloHRC
    PauloHRC God Like
    Yeah @Selmer50mark has an abacus on his dash!!!;):D
    • Funny Funny x 5
  10. mk3golfcab
    I always forget where I got upto after swearing at someone pulling out on me :confused:
  11. Bikeboy
    Bikeboy Active Member
    I was looking at the healtech ones. Never did get around to buying one. But I fancied it as it was plug and play.
  12. Blade048
    Blade048 Active Member
    I use Healtech. Easy to install and works perfectly.
  13. BikersDiscountStore
  14. garybee
    garybee Member
    Also have a Healtech, seems to work nicely and easy to fit.
  15. bazzashadow
    bazzashadow Elite Member
    and on the 12-16;)
  16. 7belowzero
    7belowzero Active Member
    Yeah! I also have the Healtech D series G2 on my 05 blade and it works just great. I do find on mine though, you must wait after switching the ignition on for it to count down and reset before starting the engine, otherwise it will show a fault.
