Gear shift indicator for RR4 ? - Easy to fit ?
Discussion in 'Mods, Upgrades, Accessories and Products' started by Fastmonkey, Sep 16, 2014.
  1. Fastmonkey
    Fastmonkey Active Member
    Want to get a gear shift indicator for my RR4 Blade, are they relatively easy to fit or is this a specialist install ?
  2. derchef
    derchef Well-Known Member
    if come with a connector (to fit in the diagnostic red one ) is easy
  3. BikersDiscountStore
  4. martinowen
    I have an acumen it just plugs into back of clocks anyone could fit!
    Also GoPro are apparently good I think they plug in same place
  5. tazmania_1981
    tazmania_1981 Active Member
    I just fitted my gearshift indicator takes about 15 minutes i bought GIPro for £109 from healtech on ebay
  6. tazmania_1981
  7. tazmania_1981
    Remove middle left cover under fuse box there is connector plug it to ur gipro job done
  8. fredaroony
    fredaroony Guest
    The install isn't hard but you do need to calibrate it by going through each gear at around 3000rpm. Easy to do on a SOLID paddock stand.
  9. tazmania_1981
    oh yeah very easy mate
    you will do it on no time
