General coolant question
Discussion in 'Maintenance' started by bonjo, Jul 8, 2021.
  1. bonjo
    bonjo Active Member
    The level seems to have dropped just shy of the lower mark.
    Never bought coolant for the bike before!
    Should I get OEM Honda or is there a better one?
    Thanks
  2. warren smart
    warren smart Active Member
    How long has it been in there, might be worth replacing it, I use rock oil iced kool.
  3. Empty_Ten
    Empty_Ten Active Member
  4. bonjo
    bonjo Active Member
    Thanks. Both those products should be good
    Coolant change is not due and frankly I may need 100ml ! So can they mix?
    called my local dealer, they said they use Castrol!
    Don’t get it what’s wrong with honda’s own
  5. warren smart
    There’s nothing wrong with hondas own.
  6. bonjo
    bonjo Active Member
    looks like honda coolant has been discontinued
    david silver has plenty in stock but no more afterwards
  7. dern
    dern Well-Known Member
    If it's not due to be changed I'd just be topping it up with water if it's only a little bit below the min mark.
  8. warren smart
    Which should preferably be deionised water.
  9. Slick
    Slick Elite Member
    I just use Castrol GP with distilled water out of the air con.
    As an aside, bought all the fancy additives to allow the bike to run cooler and TBH they made no difference!
  10. dern
    They won't, the thermostat is the thing that regulates engine temperature.
  11. dern
    It'll be such a small amount that it'll make no difference if you use tap water.
  12. bonjo
    bonjo Active Member
    I have plenty of distilled water so no issue so as dern mentioned, for such a small amount I'll just settle with that.
    I have found the coolant level must be checked with the engine at normal temp and not cold as I had done:rolleyes:
    Castrol is what my local honda dealer now stocks.
    Sure honda must have a good discount with them. First the engine oil, now coolant
    #12 bonjo, Jul 13, 2021
  13. Jez
    Jez Senior Member
    I thought it is supposed to be distilled as deionised still has all the calcium etc, But agree probably wont make much difference, I have filled my kettle 20 ish times a day for 5 years still ok, Boiler heat exchanger thousands of gallons through still ok, bike fill once in 5 years, logic says you are not going to have an issue.
  14. bonjo
    bonjo Active Member
    Got a liter of OEM Honda from David silver. They have good stock at the moment but no more once finished.
    Took 150ml to get it just above the upper level marking.
    Just as challenging as checking the oil level :rolleyes:
  15. Slick
    Slick Elite Member
    If you filled to the max at cold expect it to overflow, it will normally do this after you switch off! So if you see a puddle watch out as it is super slippy as I found out when I was showing off in front of my MD!
