Getting a rounded allen bolt out - any tips?
Discussion in 'Maintenance' started by ccr32, Dec 15, 2014.
  1. ccr32
    ccr32 Active Member
    Hi all,
    Per the thread title, wondering if anyone has any tips for getting an allen bolt out that has a (completely) rounded head? Will it have to be drilled out and then re-tapped, or is there some less painful way that I can't think of?
    It is the one holding the very rear of the lower fairing panel on just behind the kickstand, if that makes any difference.
    TIA.
    #1 ccr32, Dec 15, 2014
  2. scooby
    scooby Elite Member
    I cut a slot in the head and use a flat head screw driver where poss.
  3. ccr32
    ccr32 Active Member
    Without wishing to sound like a complete idiot (which I can be when it comes to stuff like this...!), how would you go about cutting a slot in it? I did think the same thing, but was imagining i'd need a Dremel or something to do it, which I don't have (yet...)
  4. RRoss
    RRoss Active Member
    As above,if you've got a dremmel you could cut a slot and use a flat screwdriver. Another method is use a slightly larger torx bit,hammer it in and then undo bolt.
  5. Fezza
    Fezza Active Member
    Mole grips for me if you can get hold of it :)
  6. ccr32
    ccr32 Active Member
    Thanks both. I did try that with the torx bit but didn't have one big enough unfortunately so that just span (and made even more of a mess of it!)
    Looks like a Dremel will be going on the Christmas list then...
    Cheers.
  7. SIDEWAYS
    SIDEWAYS Senior Member
    Get a latex glove cut the finger off and place the allen key into it then try removing bolt with the rubber attached.You may need to double up on the rubber but it should remove it.
    You are using the rubber to take the slack up.Good luck.
  8. ccr32
    ccr32 Active Member
    Unfortunately no can do where it is - the head of the bolt is dome-shaped to begin with, so don't think i'd be able to get enough purchase on it with any grips from the front only, and the fairing panel is in the way of going at it from both sides with a set of grips.
  9. bladerunner2010
    bladerunner2010 Active Member
    you get extactor sets for socket heads although they may be hard to find
  10. RRoss
    RRoss Active Member
    They're M6 bolts I think so with a good drill bit you could put a hole thru it and use an extractor.
  11. ccr32
    ccr32 Active Member
    Ahh... not sure why I didn't think of this - I was trying to use elastic bands to do the same thing but they kept breaking. I've now made such a mess of it that I think it is too far gone for this to work. May give it one last go anyway. Thanks.
  12. ccr32
    ccr32 Active Member
    Again, probably a stupid question, but how does an extractor work?
    I can see myself drilling the bolt out then having to re-tap the thread in the frame... :(
  13. el-nicko
    el-nicko Well-Known Member
    Get hold of a set of 'TORX' sockets and drive a suitably bigger one into the rounded cap screw. If it's too fragile to stand a whacking 'cos you can't support it from behind drill the head off with a bigger than the screw dia. drill bit. You can then remove the fairing and get a pair of 'Mole' grips on the rest of the screw that's sticking out.
  14. RRoss
    RRoss Active Member
    If I remember right these bolts have a nice thick collar on them as well so should minimise chance of damage. An extractor is a reverse threaded bit that as it tightens starts to unscrew the bolt. You need to drill a small hole thru the middle of the bolt first,3mm max and you want it right in the centre.
    #14 RRoss, Dec 15, 2014
  15. sps170373
    Put a finger from a rubber glove over the Allen key and put it in to the bolt then give it a couple of taps with a hammer or mallet which usually frees it, most of these bolts go into rubber wellnuts see if you can get a pair of pliers on the back to hold while you undue it.
    Use copperslip or molybdenum disulphate grease when you reassemble will stop it seizing in the future
  16. ccr32
    ccr32 Active Member
    Thanks again - extractor makes a lot of sense now that you have explained it, cheers.
    Torx socket trick is probably worth another go, though as I say I have made a good mess of it already so not sure there is enough material left for it to grip on to.
    Think I will hold short of trying to get the head off the bolt with a large drill bit (before using mole grips) as I am bound to go through the fairing knowing cack-handed me.
    Will have a look around Halfrauds next time I am in the vicinity and see what I can pick up, either Dremel or extractor shaped...
  17. Remal
    What I was going to suggest other than using a Dremel
  18. scooby
    scooby Elite Member
    get a dremmel,come in handy for a lot of different things.
  19. sps170373
    +1 on what scooby said, loads of use for the bike let alone the house
  20. Bart
    Bart Active Member
    There are lots of Dremel copies on ebay for a few quid, I bought one last year and has been very handy.
