Gilles RearSets
Discussion in 'Mods, Upgrades, Accessories and Products' started by Mad Matt, Mar 26, 2014.
  1. Mad Matt
    Anyone here fitted Gilles rearsets to and ABS Blade???
    Thanks.....
  2. Jap_STi_3
    Jap_STi_3 Member
    I'm starting to think we could be 'Twins' Matt Just looking at ordering a set of Gilles
    Take a look at this thread Matt may help although not ABS there are some great photos of Jamies Bike that will give you a better idea.
  3. Jap_STi_3
    Jap_STi_3 Member
  4. Mad Matt
    Cheers Ray...
    I should of said in my op that i wanted to avoid the VCR's, not sure why but have been advised not to use them and go for the standard set which are much cheaper, i will also be getting them from DT here as they have some great deals....
    The problem i have though is that my bike is the abs model and i don't want to be messing with break lines, i just want them to bolt on and play/adjust:) However i have two people telling me that the standard set will require some modifications to the break lines as they had the abs and the same issues which is what i need to avoid and i have someone else telling me there is no need for modifications of any sort:(
    So im a little confused and was looking for anyone that has these on the abs fitted with or without modifications????
  5. sinewave
    Just spoke to Andy for you Mat and he's ringing the Gilles UK Rep today to find out once and for all what the score is and will then contact you directly mate! :rolleyes:
  6. Demon Tweeks
    Demon Tweeks Active Member
    Thanks Julian.
    Just sent you a pm Matt with the details.
    All the best
    Andy
  7. Jap_STi_3
    Jap_STi_3 Member
  8. Mad Matt
    Thanks J it appears that all i need is a break switch, whatever one of those are but Andy can supply and he assures me theres no messing with the brake lines......
    Thanks Andy, i shall get some money together over the weekend and pay you guy's a visit....
    To be honest Ray i haven't got a clue but presume they look very similar to those, i mainly want them to help with my gear changes and they look extremely good:D
  9. Mad Matt
    Looking at them again Ray and yes i think those are the ones mate, they look propa good;)
  10. Demon Tweeks
    No worries Matt. I am off on Saturday but in all next week. For the ABS Fireblade you can choose either the VCR which are the most expensive or the FX which are the one's that we have been discussing.
    Many thanks
    Andy
    Performance Parts - 404 Page Not Found
  11. sinewave
    The Gilles AS31GT on the Demon Tweeks link do look good but are not the same as the FX one's in Andy's link to Performance Parts?
    I like the AS31GT units but not the FX units.
    It's the AS31GT units which need a hose extension I think?
    So it seems it's either the FX or the £460 VCR's if U want fiting with no hydraulic alterations?
  12. Mad Matt
    Yes you are correct mate the AS3's do look better but i do like the FX's. I will still have to add the Street Brake Switch which i am reliably informed needs to be soldered, so all i need to do now is see if i can find a cheap soldering machine and learn how to solder:) If i cant then i will put this on hold for now:(
  13. Clarkey
    Clarkey Member
    I know mines not a abs model but the Gilles rear sets are pure bike porn
  14. Mad Matt
    Turns out that soldering looks relatively easy and a soldering iron cost as little as £7:)
  15. graemewalker
    graemewalker Elite Member
    Don't bother with the back brake switch you don't need it you got one on front just unplug it
  16. Mad Matt
    You know what mate, i was actually thinking the exact same thing, i presume the, Street Brake Switch is purely for activating the brake light and nothing else and if this is the case then i should be good. I can't remember the last time i ever used the back brake...
    So just to confirm with everyone, this Brake switch isn't needed as its only for the brake light remembering this is an abs model?? Of course in years to come when an mot is needed i will the originals back on...
  17. graemewalker
    Don't need it yes only works the rear brake light,but you only use the rear brake turning on a tight circle using front will lock up ,not quite sure but think it will still go thru a mot with front brake switch,ask wedgie it's his field iam sure
  18. MrB
    MrB God Like
    Will need a rear brake light switch for MOT.
  19. graemewalker
    Matt the problem you have with the rearsets is getting the master cylinder to fit on the abs bikes unless they are fab bed up for it,abs don't have much play with lines behind spar ,I was 30mm short on bomancia rearsets or I would have left abs on 600 for now so I reverted back to conv lines then not a problem. image.jpg
  20. Mad Matt
    I reckon i would have sold her before an MOT is due:D
