GIpro gear indicator
Discussion in 'Mods, Upgrades, Accessories and Products' started by ColinBR, Oct 27, 2011.
  1. ColinBR
    Hi there
    Has anyone here fitted a GIpro gear indicator to they're ABS model blade.
  2. JD
    JD Active Member
    I'm sure Arthur will be along to help you out mate.
    JD
  3. ColinBR
    Thanks JD
    Any help would b much appreciated.
  4. Repsol Rob
    Repsol Rob Elite Member
    Yup a doddle mate.....
  5. Repsol Rob
    what do u want to know ?
  6. ColinBR
    Any info uv got mate. Ive not bought it yet on the basis that it's meant to be hard to fit.
    If it's pretty much a plug and play then I won't have any problems. But if it involves cutting into the wire harness then I'd defo need some help.
  7. Repsol Rob
    plug and play mate did mine in 30 mins max dead easy !
  8. ColinBR
    Sound good to me.
    Do u have any pics of where u routed it and where it plugs in or is it easy enough from the instructions.
    PS I'm not that bad with a spanner. Just don't trust myself with electrics :)
  9. Repsol Rob
    With a healtech unit easy instruction in pack, locate the diagnostic plug (adjectent to battery red blanking cover usually over it) and plug in healtech lead get the rear wheel in the air (paddock stand) start her up go through the gears revving to about 4k i think between changes back to neutral, job done....cable routes easy tucked up behind tank into battery compartment (seat off). its a bit tight for space in a abs model but it all goes back in ok, and if i can do it anyone can !!
  10. ColinBR
    Thanks Rob
    Sounds easy enough going with what your saying. I'll order 1 up tomorrow.
  11. Repsol Rob
    Should just have mentioned getting the blanking cover off can be a bit fiddly so dont be too heavy handed prising the clips (small flat blade), took mine off my abs blade the other week and fitted her to a non abs model and she did nt need programming ! it can be mounted either left hand side of clock adjecent to the two switches (route cable left hand tank side) or as i ve now got it top right enough space to stick indicator 9route down right hand side of tank.
  12. Givover
    Colin Fitted mine to the ABS model no Probs. Info and photos of the Plug in should be within the Group buy thread of this product from about 1 month ago.
  13. Jimbo Vills
    Jd - I want one of these two! Could see if we could get another group buy? If not get one and figure the install together?
    Feel a garage night coming on.
  14. Givover
    I have to say its one of the best things i have ever bought .Easy to fit, works first time ,and you know what gear you are in (No more going for 7th) Check out the old Thread .
  15. Remal
    Was put off this due to not liking playing with le cya but if it's a plug and play I will look into one over the winter
  16. Repsol Rob
    i had a accumen fitted to my old gsxr but this Gi Pro unit much better and quicker when showing gear changes.......a brill device for trackdays ......dont stop you falling off though ! My poor Abs blade !!!!!!!!!!!!!! lol
  17. Simon
    Simon Active Member
    Fitted one to my ABS Blade and it really is straight forward to fit, if memory is right the red plug is under the L/H side of the battery, I ran it up under the R?H side of the tank cover and stuck it to the top right of the clocks ....... and the YELLOW one is almost spot on match to the original backing light (08 - 11), definately need a rear paddock stand to tune it, I ran it at a constant 3k revs and when the indicator flashes just snuck it up into the next gear leaving the throttle at a steady 3k.... the only problem you will have is choosing which colour !
  18. dan.1moore1
    I went for green and love it
  19. Givover
    But Blue Rules!!! nuf said.
  20. kpone
    I've got to agree with Mike.
    I feel sick now.
