It's fairly easy, worse bit is routing round the tank to the the diagnostic socket You'll find the instal instructions here HealTech Electronics Ltd. – Smart Tech for your Ride – GIpro DS-series
piddly piss easy mate.......... just look for the diagnostic connector under seat usually got a red cap on...... and just plug in gipro........ set up and bingo !
Thanks guys. Just hope its easy removing the seat and tank cover (I'm new the the RR9)...will give it a go tomorrow after work...
There's a small black triangle of plastic under the seat which you just pull out from the end with the smallest angle, then you'll see two screws for the seat, remove the seat to reveal two Alan bolts for the tank cover, there's also two more Alan bolts at the front of the tank cover and that's your lot. Good luck. Andy B
No problem mate. It's literally two minutes if you've got the 5 or 6mm Alan key and a large Phillips screwie. Andy B
When I installed mine; I had to put the bike on paddock stands so I could run through the gears. This must synchronise the indicator. The instructions are very easily followed.
