go pro playing up
Discussion in 'Mods, Upgrades, Accessories and Products' started by Scott, May 19, 2015.
  1. Scott
    Scott Active Member
    got a 3 black thingy. It will only record about 5 minutes each time I use it and then it turns itself off ??? Thanks
  2. Muffking
    If it's not the battery then try another SD card as it could be that the card stops the camera from recording which will set the sleep timer to kick in, powering the cam off.
  3. Scott
    Scott Active Member
    Il try that if got another one. Thanks mate
  4. lambchops
    lambchops Elite Member
    What sd card have you get? Has to be a decent make
  5. DCB
    DCB Active Member
    reformat the card, job done
  6. exuptoy
    exuptoy Elite Member
    I bought a cheap 64gb card and it turned out to be a clone. Looked and checked out as a 64gb card but it would not record properly. Wife even lost a load of pics when transferred to it from her phone.
  7. Scott
    Scott Active Member
    Oh wow didn't no they could be that bad, il be checkin tomorrow afternoon. All that wasted video action just for a rubbish card. Well hopefully , hope it's not the camera
  8. exuptoy
    If u have to get a new card make sure it's class 10 with a good transfer rate. Try to buy a good brand like San disc etc.
    Have a look on www.zoombits.co.uk for cheap branded cards.
  9. RRoss
    RRoss Active Member
    Some great prices on that site but didn't see anything suitable to handle 1080p or 4K in a gopro. If you want full HD or 4K you need to shell out for a decent pro card,you gets what you pays for.
  10. lambchops
    I always buy San disk cards, ebay cheapy cards just don't work. Gopro recommend San disk also, they are now cheap I bought 64 gig for £23 quid I think..
  11. Blackness
    Blackness Active Member
    As lamby says mate. Make sure its an extreme or pro, class 10 and as fast mb/s as you can get !
  12. exuptoy
  13. Blackness
  14. RRoss
    RRoss Active Member
  15. Scott
    Scott Active Member
    Il get a new a new card then. Thanks everyone I tried the other card I had and it worked. The bad one was a San disk strangely. Hopefully the backpack battery works with a new card also. I fitted the back pack battery and it used to freeze up. Will try again
  16. Scott
    Scott Active Member
