Going up 2 teeth on rear 2005rr5
Discussion in 'Mods, Upgrades, Accessories and Products' started by sulaco, Mar 31, 2017.
  1. sulaco
    sulaco Active Member
    Looking for some help understanding, changing the gearing and the effect it has on my speedo.
    My bike has been changed from a standard rear 40T sprocket to a 42T, front has stayed standard 16T. So it is now geared as the 06/07 models are. Does this mean my speedo over reads speed, or under reads? If so how much, and do I really need a speedo healer or such? I have tried to use gearing commander website but am some how getting it all wrong, I got a 60 mph under read at top rpm in 6th gear!!!! (I think I messed up) any help/explanation would be much appreciated. Cheers in advance
  2. Dazzler54
    Dazzler54 Active Member
    It will tell you you're going faster than you actually are. Which isn't a bad think on the roads. Won't be much though.
    Go for a run out with your phone GPS switched on with some sort of tracking app and see the difference. It won't be much.
    I've gone one down on the front an 2 up on the back on most of my bikes and never bother with speedo adjustment.
  3. sulaco
    Cheers for the info, I managed to find an online calculator for sprocket changing, it calculated a 4.5% under read, which isn't too bad I guess, depending on how much the speedo was over reading in the first place. As for Gps on my phone, I'm a bit old school when it comes to phones, I've got a 7 year old Nokia which was basic at the time I bought it!!!! But I do have a sat nav for the car which I could hook up somewhere just to get an Idea of accuracy.
  4. SimonRR
    SimonRR God Like
    They are set to 5.5% more than actual speed anyway
  5. tuktuk
    tuktuk Elite Member
    Im going to put a speedohealer on mine when the sprockets are changed. Means you can have an accurate reading which keeps your mileage true also.
