Gopro trackday mounting. Whats allowed ?
Discussion in 'General 1000RR Discussion' started by IanG70, Jun 28, 2012.
  1. IanG70
    IanG70 Active Member
    Hi all. I'm doing a trackday at cadwell next week and got a Gopro to hopefully get some good vids of the day. Just wondering what type of mount they allow on track. Got the suction cup but read somewhere they're not allowed. Are the sticky mounts ok to use ? The trackday is run by MSV if that makes a difference.
  2. Repsol Rob
    Repsol Rob Elite Member
    Used a Ram mount and 3 inch arm mounted on the yolk...... never seems to be a prob... done loads of trackdays with it.
  3. Remal
    I use sticky but don't think there ar any issues re the suction cups. Only think I know is they won't allow then fixed to the body. I have the chesty to mount the go pro on the chest or back but could not use that
  4. robinh73
    robinh73 Well-Known Member
    I have only booked with No Limits and they don't seem concerned about mounts. I have used the suction mount on the tank, tail and side of the bike without any issues.
  5. abv
    abv Active Member
    Focussed won't allow anything on the tank or helmet but the type of mount doesn't matter as long as it doesn't look dangerous or likely to fall off.
  6. IanG70
    Thanks fellas. I've got a telferizer and ram arm mount but want to try some different views. Think I'll try a sticky mount on the nose under the headlights. Also just ordered a u bolt mount for the ram arm so I can clamp it on the rear footpeg for rear and low down shots. I'll let you know how it goes.
