GP Can cherping on idle
Discussion in 'General 1000RR Discussion' started by RepsolSam, Aug 22, 2015.
  1. RepsolSam
    RepsolSam Well-Known Member
    Hi,
    Fitted the exhaust I bought here recently..Leo Vince GP end can.
    Its like chirping, almost like something is vibrating in the can.
    I hear it only on idle.
    Any thoughts? Is this normal for this exhaust?
  2. Lozzy
    Mine chirps too on idle, god knows why?!? kinda like it now tho its quirky lol :)
  3. RepsolSam
    With the baffle in it sounds fine..
    I warmed the bike up thinking it may go away..on revving at standstill..without the baffle...and my years hurt! This think is bloody loud!
  4. scooby
    scooby Elite Member
    could be the inner drum lose,could be the fit isn't tight enough,could be the retaining springs are vibrating,or the rubber shroud around them has worn through,or not in the correct place.
  5. rocket
    rocket Active Member
    When your running with the baffle out do you refit the screw. If not try refitting the retaining screw or fit a small nut and bolt in the same hole.. Had a similar noise on an akropovic system on my zx12 years ago and that was the cause! :)
  6. exuptoy
    exuptoy Elite Member
    I had similar on one of my previous bikes.
