GPR dampers...easy to fit ?
Discussion in 'Mods, Upgrades, Accessories and Products' started by Kingfixer, May 30, 2014.
  1. Kingfixer
    Kingfixer New Member
    Im assuming that someone on here will have fitted a GPR damper at some point, are they relatively easy or a PITA !!. never fitted a GPR damper before or never owned a blade before so any tips ?? it's an 08 blade.
    Cheers
  2. IcarusGreen
    IcarusGreen Elite Member
    I've got one on my R6. I've had it off and on a few times and is simple although i don't know how it will be for initial fitting on a blade.
  3. Souleh
    Souleh Active Member
    I had one for a ZX6R and was simple to fit. Just take of the top yoke nut and put the bracket under instead of the OEM spacer and then it bolted to the frame at the top. Was a good job and alot easier adjusted on the move than my current CBR1000RR ohlins which is under the front subframe
  4. wedgiewolves#223
    wedgiewolves#223 God Like
    Easy to fit had one on my rr6 blade make sure you get the plug that goes into the hesd loom stop FI light flickering good bit of kit
