Groud Anchors & Chains - Any Recommendations / Deals?
Discussion in 'Mods, Upgrades, Accessories and Products' started by Ian E, May 23, 2016.
  1. Ian E
    Ian E Active Member
    Hi,
    I am looking at buying some Ground Anchors and Padlock / Chains. Has anyone got any recommendations on what to buy and where to buy from.
    Any advice appreciated,
    Cheers,
    Ian.
  2. Remal
    • Agree Agree x 2
  3. TW4T50N
    TW4T50N Active Member
    Also recommend Almax, well worth their price tags.
    Bought an Almax Immobiliser Series III + Squire SS65CS Stronghold Lock and it's a hefty bit of kit. Not one for taking in a backpack when out and about but probably one of the more harder wearing chains on the market with regards to cropping/cutting etc.
    Will be getting their ground anchor when the house is complete.
  4. RRoss
    RRoss Active Member
    Definitely almax,sleep easy knowing that's attached to bike. Nothing's 100% thief proof but they're gonna make a lot of noise cutting that.
  5. Ian E
    Ian E Active Member
  6. Remal
    if you say your on Pistonheads :) you should get a discount
  7. Hedges
    Hedges Active Member
    Got myself an Oxford anchor force, along with a Oxford hardcore chain! Good piece of kit!
  8. dansp1
    dansp1 Active Member
    have a look at the vids on the Almax site
  9. RRoss
    RRoss Active Member
    6mm shackle on that ground anchor,compared to the 13mm on the almax chain that would be a definite weak point. Maybe suitable for a push bike but I'd go for something bit more substantial.
  10. Ian E
    Ian E Active Member
    Good point - thanks :)
  11. sinewave
    Almax all day long.
    Everything else is inferior.
    I have 2 of their chains and the Ground Anchor, the Red one in the below Pic and the Blue one which is seen loose below but is usually wrapped around the Track Bike Wheel too, but in this Pic it was still in the back of the Van.
  12. RRoss
    RRoss Active Member
    Got it wrong,16mm is the smallest one they do which is the one I use.
  13. Ian E
    Ian E Active Member
    Thanks for all the advice - I think I will go for the Almax one.
    What is the best way of securing a bike with a chain / ground anchor? i.e. front wheel, back wheel or whatever? Just wondering which length chain I need.
  14. RRoss
    RRoss Active Member
    Ideally thru the frame but nearly impossible unless you use a thin chain,which kinda defeats the purpose. Front or rear,there is a possibility they could remove the wheel but scroats don't usually carry a full toolkit,and they couldn't then push the bike away. Put ground anchor inbetween bike and wall so its harder for them to attack.
  15. Ian E
    Ian E Active Member
    #15 Ian E, May 24, 2016
  16. ray
    ray Well-Known Member
    Another vote for Almax.
    Give them a call and you'll get a deal on the chain, lock & anchor combo.
    Plus nice guy to deal with and he'll chat to you forever about bike security.
