Hard to drop the lump in a 2010
Discussion in 'General 1000RR Discussion' started by Joe #4D, Dec 15, 2015.
  1. Joe #4D
    Joe #4D Active Member
    Hay all thinking of dropping the lump out of my 2010 blade.
    For engine work. Is it hard or easy??
  2. ColinBR
    As far as I can see it's pretty simple.
    I'll be doing the same over the Crimbo period with the track bike to slot in a new engine.
    Certainly looks easier than my SP1 and that wasn't exactly hard either.
  3. Joe #4D
    Cool yer it's my track bike too. At the mo it's in my garage tank and air box off. And I'm looking at it. Thinking there's not much left .
  4. ColinBR
    Only thing you'll need is the engine removal tool for the castle nut.
    Though you can stake it off if you ain't too fussed
  5. Scott
    Scott Active Member
    It's easy enough really. Heavy tho. And can make the tool out of a socket and with a grinder
  6. ColinBR
    Yea that's what I done for the castle nut. I just milled the castle form into an old socket
  7. ColinBR
    Looks likely that I'll be dropping the engine on my track bike on Friday. I'll let you know how it goes.
  8. scooby
    scooby Elite Member
    piss of piss,just make sure all engine connections are off.
    hardest thing is loosening the top frame/engine spacer at the rear,the tabs snap easy on them.
  9. derchef
    derchef Well-Known Member
    in 75 minutes from a running bike
  10. ColinBR
    It's is very easy on the blade. I've just done mine over the weekend. Even easier than the SP1 and that wasn't hard.
