I got some harris rearsets for my rr7 and ive got round to fitting them fitted the left side but im having trouble fitting the brake side i think i may be missing parts or i just cannot figure it out how it goes any pics of how it all goes together or info on how these fit would be greatly appreciated
Got them on my SP2 but fitted a brake light pressure switch as the standard switch is messy to fit on these. Post a pic of what you have as there are diff models.
My quess is that there isnt a return spring but a long lightish spring for pulling on the switch also i reckon u are missing a pin that goes thru the hole in the lever also to work on the spring and you are missing a bracket that the original switch should mount on. Forget the lot and get a banjo bolt pressure switch and rely on the hydraulic pressure returning the lever. Also grease the bush.
Got it sorted thanks n1xxl i am missing all the spring bits there are threaded holes but i dont have anything to go in themwill get a banjo brake switch ordered and thanks charger it didnt need the spring i does work on its own
