Hi All, need some advice. Whilst replacing my CBR '08 nose cone with a friend he accidently turned the wrong screws to try and release the nose cone section. He turned the two large(ish) grey colour screws repeatedly. When that didn't release the nose cone we actually figured out the ones that release it. I believe the grey screws are used to align the headlamps? Is that correct? if so how do I get them back to normal position?
there are 2 bolt/screw per light horizontal & vertical If you can remember the number of turns, then try reversing that. You can get the light beam height & angle and you can do a home alighment, alternatively take it to a friendly MOT garage and use their lens equipment
