Healtech DS G2 Gear Indicator Advice RR7
Discussion in 'Mods, Upgrades, Accessories and Products' started by jayrepsol, Feb 29, 2020.
  1. jayrepsol
    jayrepsol Active Member
    About to have a crack at installation tomorrow.
    Any hints or tips?
  2. Barstewardsquad
    Does it connect via the diagnostic socket? If so it is behind the left hand fairing as you sit on the bike, and the cable will route easily behind the dash.
  3. dmc12
    dmc12 Well-Known Member
    Yes, it's dead easy - as long as you've got the right one. I had one with (almost) the same part number and it had a different shaped plug.
    Also - make sure you've got a rear paddock stand. Far easier to calibrate on that than trying to do it on the road.
