hi anyone using the healtech quickshifter?? If so what settings you running on I seem to be hitting false neutral between 4-5th gear around 80-90mph any way of stopping this please ???
This is what I use, I have Gilles VCR rear sets so perhaps this is slightly different to the standard foot peg set up
Also bear in mind this setting reacts to a chain tightness that is spot on, when it was a bit slack it missed like a sod, so again dependant on your configuration
Yeah adjust your cut off delay 5-10ms, give it a run and see if it feels better or worse then adjust accordingly
