I'd be interested in getting some stainless steel clutch and brake hoses. This looks shockingly cheap http://www.ebay.com/itm/39cm-15-Mot...-Fitting-Stainless-Steel-Swivel-/381909330923 Brake hoses are not a place to skimp on haha. HEL - Looks decent http://www.ebay.com/itm/Honda-CBR10...-Brake-lines-hose-kit-Crossover-/182479401555 Clutch Hose options I only found 2 options http://www.ebay.com/itm/Goodridge-stainless-hose-Zinc-plated-steel-fittings/400850012099 http://www.ebay.com/itm/Goodridge-stainless-hose/291056771257 I don't know if there's any difference. They're the same brand. http://www.ebay.com/itm/HEL-HBC2689-Stainless-hose/201829757024
Would avoid the Far East stuff for hoses! Hel, Goodridge, venhill are all equally good and about the same prices
I've used most brands (not cheap shite)over the years, for road use they are all pretty much the same. I do like Hel, but Venhill are best for ease of fitting( the banjos can swivel) My current bike has Wezmoto, first time I've tried em and I'd say they were perfectly fine for road use and fairly cheap compared to others. I'd also go for full length race set up as it is far easier to bleed. As for the clutch line, never really seen the point in changing it, other than for looks.
I've got Hel on mine, recommended by friends & other blade owners. Can't fault them. Speak to Dave at BDS (Biker Discount Store), he's on this site & he'll sort you out. http://1000rr.co.uk/threads/hel-brake-lines-offer.15593/
Been using HEL for 20 years, most of the TT lads use them. And I've seen what can happen to the good ridge alloy banjos, and you don't want that when riding.
I have just fitted the HEL ABS set to my blade, I have had a few problems, 2 of the original manifold blocks that fit onto the solid pipework are tapped M5 to attach to the bike, the new ones are all just drilled 5mm, also the hose from the front master cylinder was out 180 degrees to fit the existing solid pipework. I am going to email HEL for their reply.
