Help meeeeeeee
Discussion in 'Mods, Upgrades, Accessories and Products' started by Yorkshire Tyke, Apr 9, 2013.
  1. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    Does anyone know the thread and pitch size of the lambda sensor on an 08-11 blade? I've just bought a yoshimura r77 used off ebay and it came without a lambda sensor bung and the internal thread where it would go in the exhaust is cross threaded. So I need to try and re-tap it and then find a bung from somewhere...
    Any help would be very appreciated!!
  2. Si.
    Will the lambda sensor not screw in at all??
    Sorry i can't help mate, i'm sure someone will be along shortly who can though...
    Have you mentioned it to the seller, maybe get a few quid back??
    I may have a bung as i didnt use mine (it's just closed nut) i have just left the sensor unplugged at the top and used the o2 eliminator. i'll have a look later.
  3. phantom
    phantom Active Member
    Get a set of vernier on it.
  4. Yorkshire Tyke
    No can't get the lambda sensor in and since I put the PCV and o2 Eliminator on I've removed the lambda sensor, would just cut it and use it as a bung but the exhaust hole needs re-tapping. Looks to me like an M12 thread but the pitch definitely isn't 1.75mm on the lambda sensor so who knows! :)
  5. Slick
    Slick Elite Member
    On CB1000R it’s definitely M12x1.25 fine thread as I bunged it following fitment of a PCV, - don’t see any reason why it wouldn’t be the same for a blade!
  6. Yorkshire Tyke
    Cheers slick, i knew it deffo wasn't standard pitch! Nice one
  7. phantom
    In the engineering place I worked 1.25 pitch was the srandard lol
  8. Yorkshire Tyke
    1.25 is fine thread at nestle or maybe 1.0mm? now i'm questioning myself!!! lol anyway re tapped it, found a 12mm bolt and annealed a home made copper washer, that bitch now aint going nowhere!! :D
  9. Slick
    Slick Elite Member
    So all sorted now?.
  10. Yorkshire Tyke
    Yeah all sorted cheers for input everyone, ever helpful as always :)
  11. phantom
    now you can get the bypass plug fitted and have fun again.
