Help needed. Egr exhaust valve
Discussion in 'General 1000RR Discussion' started by Liddell98, Aug 11, 2018.
  1. Liddell98
    Liddell98 Active Member
    Hi guys, managed to get a full front exhaust without decat, now I'm wondering if it's possible how to I do away with my egr sensor?
    If I unplug it the engine management light comes on which is a pain, I use my bike for racing and track days.
    Thanks in advance!
  2. Bikeboy
    Bikeboy Active Member
    Are you doing this to a car? Or have you got your terminology mixed up... 02 sensor maybe ?
  3. Liddell98
    Yeah o2 sensor lol! I've been speaking to a place not too far away and instead of a power commander I'm going for a ecu flash instead, seems to sound the part anyway and from what I gather it will sort out not having the sensor either
  4. Bikeboy
    I'm looking down that route too.
    They code out the 02 sensor when they flash the Ecu
  5. Liddell98
  6. Spygoat
    Spygoat Well-Known Member
    My exhaust came with an o2 eliminator that you plug into the harness (where the o2 would normally plug in) since the aftermarket exhaust has no rear o2 sensor. Might be less than an ECU flash.
  7. tuktuk
    tuktuk Elite Member
  8. Liddell98
  9. Liddell98
    Cheers, although I think the ecu flash will give me more gains also, make the bike alot smoother and I beleive it gets done on a dyno so it will get bike running at its best with my current exhaust set up etc
