Help needed if anyone could please
Discussion in 'General 1000RR Discussion' started by Karlanthonycox, Sep 17, 2016.
  1. Karlanthonycox
    Karlanthonycox New Member
    Hi I need to get a couple of new bolts for my rear sets on my 2005 blade, I used lock tight on the bolts which secure the rear sets too the frame, unfortunately I have come to remove them and one bolt has rounded off, I'm just unsure about what to order, many thanks in advance Karl
  2. sp1n99
    sp1n99 Active Member
    First thing I'd try is a rubber glove between the bolt head and socket if the heads not too rounded. Failing that I'd dremel a slot in the bolt head to use a large flat screwdriver.
  3. Karlanthonycox
    Thank you for the reply mate, I should of specified I managed to get the old bolt out but I just need to order replacement bolt, not sure on thread size, I cant use original bolts because the head of the bolts are too big to go inside the rear set many thanks Karl
  4. sulaco
    sulaco Active Member
  5. Karlanthonycox
    Your a star thank you mate!!!!
