Help needed re - ohlins rear shock
Discussion in 'Mods, Upgrades, Accessories and Products' started by Remal, Jun 26, 2013.
  1. Remal
    A chap I know is selling one he had on his Non ABS 2011 blade.
    is there any difference between the ABS and non ABS with regards to the rear shock?
    i need to find what model it is, I have no idea yet
    Any help
  2. exfire
    exfire Elite Member
  3. Remal
    it's a TTX mate but thats as far as I know
  4. Remal
  5. exfire
    exfire Elite Member
    According to the Ohlins fitment chart that model fits an 08 to 012 Blade. The link you put up says it fits with or without ABS. If yours is an 08 -012 it should fit but you could always check with an Ohlins supplier.
  6. Remal
    what I was thinking and took 30 mins to get this page up
    ROB!!!!!!!!!
  7. Remal
    ROB!!!!!!!!!
  8. Slick
    Slick Elite Member
    Looked into this when speccing my dream CBR (if I had a few grand to spare, as you do:) )and looks like most upgrades are the same between the abs and non abs including front and rear suspension.
    I found the main diferences were brake lines- you need more, hugger - need more clearance, exhaust that use the servo - need a longer cable and discs, they need to be tapped to hold the speed sensor rings.
  9. Remal
    £450 for a ohlins TTX shock, is that good?
  10. Alblade
    Alblade God Like
    Remember the 2012 shock is a twin tube unit and while maybe not quite ohlins is another good upgrade option to consider for a load less money.
  11. exfire
    exfire Elite Member
    Hi Remal. I think they are about £1200 new, they usually go for anything from £500 to 600 second hand. I got one second hand and then had it serviced just to make sure it was in perfect working order, service cost me £80 from memory. So 450 sounds very good to me.
  12. Remal
    cheers mate, how easy are they to fit?
    Anyone know
  13. exfire
    exfire Elite Member
    Sorry I don't know, the garage do mine.
