Help needed won't start
Discussion in 'Maintenance' started by Shutty, Mar 11, 2016.
  1. Shutty
    Shutty Well-Known Member
    guys I'm in need of help
    2008 Blade, just been synching in a gear indicator and running it through the gears on a paddock stand, wouldn't synch so took a few goes and hence starting and stopping bike whilst reading instructions
    Now it won't start
    Battery is ok, I can hear the fuel pump buzz, fuses under seat are good
    It struggled the previous time and I thought I had flooded it so held the throttle open a bit and when it kicked in it rev'd to about 11,000 before I had time to release the throttle and now it won't start, just spins as if it's no fuel but it does
    Any suggestions, was planning a ride tomorrow
    Help
  2. sps170373
    did you try with the gear indicator unplugged?
  3. Shutty
    Yep tried, tried the other key swapped the fuel pump relay, tested all the fuses, i can hear the pump prime but not getti g any unburnt fuel smells when turning it over
  4. racman
    racman Active Member
    silly question i know, but you have got fuel in havnt you?
  5. graemewalker
    graemewalker Elite Member
    Not in gear is it pull the clutch in and try sounds like in gear daaw
  6. racman
    also food for thought. i had a cbr600 steelie track bike. was non start one day after it had been running perfectly. the problem was that 1 spark plug had failed rendering it a non start not even attempting to fire on any of the other 3 cyls
  7. Shutty
    Full marks to Racman
    What a wan£er I am. The gauge showed just 1.4 used,and I could see fuel in the tank, but I forgot how long I had it running over winter when doing the coolant change idling whilst bleeding it. I undid the tank and strapped it upright and tried it and it fired up.
    Suppose it could have been worse, I could have been 3 mile down the road tomorrow morning
    What a to$$er
    • Funny Funny x 2
  8. graemewalker
    Well done Racman who needs a manual barrel of info on here
