Help needed
Discussion in 'Maintenance' started by Willie 1000rr, May 26, 2017.
  1. Willie 1000rr
    Willie 1000rr Active Member
    Fitted rear sets to my 16 blade, linked up rear brake and wired into the loom, since doing that the bike isnt starting at all, turn the key and all the lights etc are flashing on and off and making noises, any ideas what could be up? Any help welcomed. Thanks
  2. thewiz
    thewiz Active Member
    Uplug it again i suppose. If the bike starts normally, that is the problem. Take it up with the dealer.
  3. blake7
    blake7 Active Member
    It's just the brake light and should have no link to the bike not starting. When you say connected to loom, Is it a pressure sensor banjo switch that you have fitted?
    You normally just cut the connector of the existing brake switch and join to the pressure switch. That was you are not altering the loom at all.
  4. Drezic
    Drezic Active Member
    Dare I say it......kill switch?
    Only as I had a mate who did the exact same thing!
  5. Barstewardsquad
    +1 or the sidestand switch.
