i replaced my oil filter and oil and air filter the other day went out for a ride today only a nip round the block all ok till i went round an island got it on the straight give it some then cut out ,ive been told that because ive tilted the tank too far up when replacing the air filter i may of upset the hiss,got lights all ok but nothing on the start button..had to get a tow home that shit me up so dont fancy doing that again, please help its a 954 blade thanks guyz
Does the 954 have a Tilt Fuel/Ignition cutout switch like the later Blades? If so you may have dislodged it and when you went around the island the lean angle was enough to activate it?
I'd be looking around the kill switch and side stand areas before you starting getting to deep in to it.
