HELP PLEASE!!!! Throttle adjustment!!
Discussion in 'General 1000RR Discussion' started by Vajco12, Mar 19, 2013.
  1. Vajco12
    Vajco12 New Member
    Hi boys, can anybody tell me how I could adjust Throttle, handle grip I mean. Well, there is little gap between when the grip is twisted before power arrives. If it make sence. Look like my handle grip is little loose, I mean there is like 3mm when I twist before i get to the point where bike respond. Thenks
  2. wedgiewolves#223
    wedgiewolves#223 God Like
    Fine adjustment on cables crack the 10mm nut twist the longer part keep checking while doing then lock off nut it's the top cable coming out housing ImageUploadedByTapatalk1363715214.915638.jpg
  3. Vajco12
    Vajco12 New Member
    Nice one m8.. Thanks
  4. wedgiewolves#223
    No worries anytime
  5. sinewave
    There is supposed to be a small amount of free play just like the clutch cable.
  6. wedgiewolves#223
    I think they do say 2mm this is too allow for lock to lock on steering I don't like any play so adjust it so minimum play turn bars lock to lock just to make sure ok
  7. sinewave
    It's also to allow for any expansion/contraction in the cables as well.
    If you adjusted the throttle for zero play when it's a warm day after a ride then the cables will be at max expansion.
    There is then the possibility that coming back to your bike on a colder day that the contraction in the cable/ancilleries is enough to make the engine race a tadge, which on the Blade could be quite dangerous with that amount of power.
  8. Toy40
    Toy40 Active Member
    the play is there also so as not to make the trotel response too snatchy and dangerous
