Hi, Hope you can help. Pulled bike out of the garage to take it for an MOT, and whilst it started and ran, the high beam dash light was permanently illuminated. High beam didn;t work (swapped bulbs to check). All indicators on solid, and dull. Horn is very weak. When I pull the headlight / starter 20A fuse, Dash light goes off and I hear the fule pump prime! Ground wire looks ok, can;t see anything obvious? Anyone got any ideas?
