Help removing GSXR engine
Discussion in 'Lounge' started by Yorkshire Tyke, Oct 5, 2013.
  1. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    I've stripped the trackbike down today and removed nearly all the engine bolts. There are only two left and I can't for the life of me get them out, they are like a threaded bush thingy. Tried a 19mm too big and 18mm too small lol.
  2. ColinBR
    That looks something like the threaded castle nuts that I have on the SP1, and I had to make (you can buy) a special tool to remove them.
    Type in engine removal tool in ebay and see what comes up (for your bike obviously)
  3. Yorkshire Tyke
    I've had a look for a tool but found nothing cheers anyway col
  4. ColinBR
    Arthur may be able to shed some light on it then.]
    He is the man ;)
  5. dave d
    dave d Elite Member
  6. wedgiewolves#223
    wedgiewolves#223 God Like
    Hi buddy you have took the castle nut off these with the 4 notches ? A 19mm socket does I I took a engine out yesterday but it had to be the 6 point socket looks like a nut not the 12 point socket buddy
  7. phantom
    phantom Active Member
    its imperial which is why the metric ones wont fit ;)
    took a k4 one out before think its something like a 3/4"
  8. Yorkshire Tyke
    What I'm talkin about is apparently the engine spacers. Gonna have another tickle with it tomoro when I can see what I'm actually doin lol
  9. wedgiewolves#223
  10. phantom
    that one on the right (last pic) back it off and it comes out and pulls the spacer out of the engine
    allowing in to drop.the bolt on the left attached to the to long pin needs removed first.
  11. phantom
    the nut on the right and rod are all one bit, this comes out first
    then when you turn the imperial nut on the left(the rounded one)
    the castle nut stays in place and the spacer retracts from the engine.
    you can then support the engine and remove the engine bolt under this
    one allowing the engine to drop out.
  12. Yorkshire Tyke
    I will have a look at this tomoro phantom but I'm pretty sure the spacers aren't the castle type like the pic above.
  13. phantom
    thats from a different model but its basically the same idea with or without the castle nut
  14. dave d
    dave d Elite Member
  15. ColinBR
    Ok I would say that, that is almost the same setup as the SP1.
    I would say that I would not take out the bolts first though.
    If I remember right, once you undo the castle nut you then supported the engine, before winding the engine spacers back.
    Then making sure the engine was fully supported, removing the large bolts. (the engine hangs from these and takes a bit of wiggling)
  16. phantom
    there is another engine mount directly below this on which I leave in as well as using a jack to
    help support it.
