Help Required: RR4 Exhaust
Discussion in 'General 1000RR Discussion' started by nigelrb, Mar 14, 2018.
  1. nigelrb
    Can anyone tell me, when a R & G tail tidy is fitted to an RR4, if there is provision to fit the original black and silver plastic heat shields? I have seen pics on R & G website, and phoned them, but I cannot obtain a definitive answer. I am suspecting the R & G brackets might not accommodate. Has anyone modded this?
    Pic 1. Original RR4 (no tail tidy) with heat shields
    Pic 2. Original RR4 (with tail tidy) no heat shields
  2. PauloHRC
    PauloHRC God Like
    You looking at another bike Nigel??
    Looks like the R&G is a bit tight to accommodate the original heat shields there mate. The exhaust doesn't look too clever with them missing does it!!! o_O
  3. nigelrb
    Yeah, found a mint 2004 with only 4,500 miles (verified by MoTs).
    I'll probably source the standard number plate fender and reinstate the black/silver trim if I can't adapt, or if no one's able to offer a solution. It just looks unfinished as is.
  4. PauloHRC
    PauloHRC God Like
    Just found these while looking for a heat shield for my stock exhaust.
  5. nigelrb
    Cheers for that, Paul. Yes, it does seem they're readily available. I've downloaded the schematic parts diagram from Fowlers so I can order the appropriate mountings etc.
  6. sulaco
    sulaco Active Member
  7. nigelrb
    Cheers, Sulaco. You've probably seen on my new thread (My eBay Gem) that I have the original goodies. Was merely trying to find out if anyone had adapted the R & G. I've set my mind to putting it back to original.
  8. sulaco
    Oops sorry , stick and wrong end spring to mind.
