Hi all. I had bike stripped and changed quickshifter and system. When bike got up to temperature (85 degrees) idle has jumped up to about 1800rpm compared to 1200/1400rpm. I have it stripped again and everything seems to be connected ok and in place. I have no idea. Any suggestions please?. Thanks
Quickshifter should have no effect on idle. Jump in idle RPM sounds like a vacuum leak. Only suggestion is to check again - airbox seated right, hoses under it connected properly - oil vapor and PAIR system hoses. Vacuum line for MAP sensor. My bet is on the vacuum line as it is so easy to miss.
