Help with fitting new flashers
Discussion in 'Mods, Upgrades, Accessories and Products' started by Alan Summers, May 16, 2020.
  1. Alan Summers
    Alan Summers Active Member
    Can someone tell me what I need to do to get the new flasher wiring to fit into the bike wiring please. I'm a bit of a dumb shit and am fearful of messing it up. Have the resistors. 20200516_113849.jpg 20200516_113849.jpg 20200516_113857.jpg 20200516_113849.jpg
  2. Alan Summers
    Like I said.. a dumb shit, dont even know how i have uploaded the same pic 3 times.
  3. Wes
    Wes Active Member
    Your indicators are fed from the blue and orange plugs. Your new resistors will go in between the plugs and your new indicators.
    From your images I’m guessing that your new resistors are the yellow and black and the indicators are the black and red. Basically black to black red to yellow from one end of the resistor.
    The remaining black and yellow connect to your existing wiring.
    Keep your plugs and work with the slack. It looks like your orange and blue from each indicator will be going to the yellows.
    Leave your ignition off, do one side at a time and check before you start the other side.
    I don’t 100% know this is all correct but my best guess from your images.
    Best of luck mate.
  4. Alan Summers
    So cut the old connectors out and join the new wires to the bike somehow?
  5. Alan Summers
    Just done the right hand side and it's working but flashing quick. I thought the resistor would change this? Can someone confirm please.
  6. Wes
    Wes Active Member
    Are you installing led indicators ?
    If the indicators were working before and your new one has introduced a rapid flash then the resistor is not doing its job.
    How have you connected it up ?
  7. Alan Summers
    I've connected as you said above. Joined the wires that you've stated. The hazards flash normal but the flashers are quick.
  8. Alan Summers
    And yes they are led's, r&g resistors
    #8 Alan Summers, May 16, 2020
  9. Wes
    Wes Active Member
    Sorry I didn’t even consider the hazards and I don’t know what impact they have. You might find the only way to rid yourself of the rapid flash is to swap the indicator relay out for an led one.
    Have you double checked your connections and swapped to a different new indicator ?
  10. Jez
    Jez Senior Member
    Each of the 2 wires going indicator should have one of the led wires and a resistor wire on it.
  11. Carl S
    Carl S New Member
    Any1 added any led mirrors to the 07 model
