Help with Waterproofs..
Discussion in 'General 1000RR Discussion' started by samuk, Jul 11, 2012.
  1. samuk
    samuk Well-Known Member
    I need some help...as i commute to and from work..and this shitty weather i need some waterproof bottoms..
    I currently have a pair of bottoms that i can pop on over my jeans etc..but i find them little thick and uncomfortable..and they feel like plastic!
    I wanted something better that is
    Easy to pop over my existing bottoms
    Something light and small in size (something thin)
    I can preferably roll it up and keep it under the rear seat cowl
    So does something exist?
    I was thinking about buying something like this, but more then likely i would think these would only be used for bike trips...
    any good?
    Arlen Ness waterproof trousers | eBay
  2. Remal
    It would be better to have a waterproof all in one. saves getting wet around the middle. less joins the better and more waterproof you should be. I wore HG texttles top and bottom and they did a great job for the 2 years I commuted in all weather
  3. samuk
    i have a waterproof jacket...
    i wanted something i could easily pop on and off..as having another layer is bloody uncomfortable
  4. samuk
    and my commute to work is only 10miles...
  5. Hudson
    Hudson Active Member
    Your journey was exactly like mine..... i have a set of Deluge over trousers, they are from Blacks camping and are not specifically motorcycle related, they do however have a great feature that they zip all the way to the top of your hip, so putting them on and off is just so easy, have a look on the net at them.
