Hi all just joined today
Discussion in 'New Members' started by Blade lover, Nov 16, 2012.
  1. Blade lover
    Blade lover New Member
    Can i be cheeky please i have a question why does the clutch on my 2004 Blade keep needing to be bled?
  2. phantom
    phantom Active Member
    welcome aboard.
    I assume you have already checked for leaks?
    I do know there is a lot of people that have trouble bleeding
    them and the main points I heard before was use a speedbleeder
    and to make sure the bike is level and doesnt have the rear in the
    air i.e. no rear paddock stand.not sure if this would make much difference
    but hey every little helps.
  3. martinowen
    Hi welcome, can't help with your question but there is plenty of people on here that will be able too. Note they will probably trade this useful info for pics of your pride and joy ;)
  4. ColinBR
    Make sure you crack the banjo's at the clutch side. I always find that once that is done its just a case of bleeding at the slave cylinder.
  5. Bobmg
    Bobmg Active Member
    Welcome aboard , I am sure you will be able to find all the answers you need on here as regards to any problems you may have , lots of helpful people just ask , good luck with the clutch
    Bobmg :)
  6. Remal
    welcome to the forum, I have no idea but hoping like the above posts the guys on here can help
    seen your local. Where in Bristol do u live? I'm in Hanham :)
  7. hrc oz
    hrc oz Member
    hi and welcome aboard :)
  8. bubba
    bubba Member
    hello blade lover and welcome;)
  9. SIDEWAYS
    SIDEWAYS Senior Member
    Welcome:)
  10. GappySmeg
    GappySmeg Well-Known Member
    Welcome...... as said, dont think the clutch line should need regular bleeding so you've either got a little leak somewhere, or its not being bled properly.
  11. Nutty Tart
    Nutty Tart Well-Known Member
    Get out now .... save yourself .... don't look back just go :p
  12. kpone
  13. Freedom of choice
    Run fella run......
  14. Nutty Tart
    TOO LATE ............... :eek:
  15. ieathaggis
    ieathaggis Active Member
    Hello and welcome
  16. BlackDevil
    BlackDevil God Like
    Hi and welcome !
  17. Fozza
    Fozza New Member
    Hello and welcome, there are some great guys on here who are very helpful. Hope you sort your problem out before the weather gets better so you can get out and enjoy the Blade.
  18. Jamiestrada
    Hi and welcome
  19. Only1Matrixxx
    Only1Matrixxx Active Member
    Welcome to the mad house!!!
  20. masterblader
    masterblader Active Member
    Hi and welcome blade lover.
    The hydraulic clutch is a right beggar to bleed to get maximum pressure at the lever. Have found the conventional way was ineffective and resorted to back bleeding in that you remove the piston from the slave cylinder fill the chamber with fluid gently replace the piston and push fluid into the reservoir. A two man job to ensure theres no overspill, worked every time with me bud. Best of luck.
