Hey guys, I tried searching to see if anyone had the same problem as me but I came up with nothing, this has only just started doing this. When my bike is in neutral everything is fine and it idles at 1500rpm but when I put it in first gear, they jump up to 3000rpm or so. Also another question I find the throttle on from no throttle is a bit jerky and not a smooth transition, not ideal in the corners.I looked to see if the grip was rubbing on the bar end but it isnt. Any ideas? Any solutions?
