HISS reprogramming gonna have a go 08+ bit of tech reassurance needed
Discussion in 'Maintenance' started by wedgiewolves#223, May 2, 2013.
  1. wedgiewolves#223
    wedgiewolves#223 God Like
    I used to add my own key and for friends on the HISS system on the 04-07 bikes all the time. I ve been asked by a member if i can do the 08 onwards so ive had a look into it . Im ok with locating stuff and doing it but i need reassurance that i have my wires correct as the manual makes it hard for my little brain to understand.
    Its done through the CKP (crank sensor always 2 wired and red plug)
    on the earlier blades this was behind side fairing.
    Ive located on the 08 bikes that it is behind around the starter motor so i dont think ill have to remove any fairings .
    Now i have looked and it seems that the + is the yellow wire
    and the negative -is the yellow/white wire can someone back me up on this .
    Im sure it was the same wires on the earlier models and i needed someone the reassure me that i was correct .
    Im gonna try my 12 first and i already have the lead made and forum members if they can get to me with cut and blank chipped keys ill do them free.
    YOU MUST HAVE 1 WORKING KEY AND ONLY ARE ONLY ALLOWED 4 KEYS TO BE PUT INTO SYSTEM.
    HISS new spare key programming coding - here is how to do it !! : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
  2. martinowen
    Feeling brave! Hope it goes well
  3. Alblade
    Alblade God Like
    One option could be this... I bring my bike down with the bust ECU to test - yes its a hassle to swap them over - see if we can clone a key if all good swap the ECU over and code a key to my working ECU (its only the rev counter that has failed)
  4. wedgiewolves#223
    Yeah tis a good idea get a spare key sorted and we will have a bash
