Fitted one to my bike f1 light came up and struggling to get gear indicator working just had a email about gear indicator go into set up advanced and make sure it's on stock not GPS I'll try this in the morning see if it works any ideas would be greatfull
Don't know about the F1 light, mine worked without any issue. Assume you've set up the gear indicator? What's the symptoms?
Tried setting it up manually been told to go into menu settings change it to stock and do it manually again I'll try it again tomo as for the f1 it's not effecting the bike and there's no fault codes 2 people I spoke to in almeria has the same thing just a bit anal want everything right lol
It just shows a - on race mode and n when it's in neutral Iv tried setting up manually going through the gears but hasn't worked then someone on Moto forum said they had the same problem try going into setup then advanced then change it to stock not gps also no speedo showing on the bike
Sure it's in stock from HM, so unless you've change it imagine it was? Sounds daft, but you have got the back wheel moving when understanding if it's working? Mine only shows - or N unless the wheels rotating.
Yeah it's moving lol I'll try it tomo Dave on stock run it through the gears in a paddock stand and let u know thanks for the help bud
No worries mate, sorry for asking the obvious. I set mine up going down the motorway, racefit way too loud to be doing it on a paddock in the garage or on drive. Good luck
