HM Dash issue
Discussion in 'General 1000RR Discussion' started by Gixxa84, Sep 10, 2018.
  1. Gixxa84
    Gixxa84 Active Member
    good evening all,
    I have a 2009 fireblade with a HM Dash fitted. It works well but every so often as you ride along the screen goes blank, the rev lights all come on, it then displays the boot up screen (sowing firmware and bike model) before working again. Seems completely random too.
    Anyone seen a similar issue?
  2. roboticus
    roboticus Active Member
    theres a clip holding the wires into the dash,the clip might be broken, why is there a hm dash on it, he might of replaced the oem dash with hm dash because the oem got broke, braking the clip in the process, its pretty tight under there and theres a rubber collar holding the wire to the dash as well as a clip, clip might be broke so only collar and the tightness holding it in place, it means taking front end off and if it is the clip broken don't think there much u can do as the clip is on the loom side
